53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> View Discipline Parameter
Mon, Mar 4, 2013 at 2:31:06 PM | View Discipline Parameter
Ellie02
Hi there,
In my title block I would like an automated parameter that covers view discipline.
So in my title block i have a label that has a parameter assigned to it called discipline. this is a shared parameter and is visible and i can type in text to amend it in the title block within the project. However, when i place a view on a sheet i would like it to automatically update the title block to show the view discipline from the project browser.
So our drawing titles usually go:
Electrical services
(then the drawing title) parameter for this is working perfectly.
Is it possible to have a parameter for a view discipline and how should it be set up?
Mon, Mar 4, 2013 at 3:08:40 PM | View Discipline Parameter
Your problem is that sheets can have multiple views ... with each a different discipline.  I don't see any way to make this automated.
Controlling Display setting per Discipline
Fri, Feb 17, 2012 at 12:33:04 PM
Sub Discipline under Views?
Fri, Apr 17, 2009 at 2:21:21 PM
Discipline - structural
Mon, Jun 12, 2017 at 2:38:52 PM
Can't find Sub-Discipline in Properties
Mon, Jan 27, 2014 at 5:24:22 AM
Ceiling Grids in Electrical Discipline
Sat, Feb 23, 2008 at 9:36:22 PM
Page generation time: 1.7844
