45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Can't see analytical properties
Sun, Mar 3, 2013 at 1:16:22 PM | Can't see analytical properties
stjern
Before I have only made my own projects but now I have to use a project I didn't make myself. The problem is that when I go to a wall and click "edit type" it doesn't look like my other projects. The fields "heat transfer coefficient", "thermal resistance" and "thermal mass" are just blank. In my other projects these fields have values. It's the same for the other objects like windows, doors and roofs.
I want to change the objects to have the right materials and U-value but it's very hard since I can't see them! It's like the person who made the project has disabled the option for the program to calculate these properties.
Thank you in advance, Johan.
Mon, Mar 4, 2013 at 12:39:54 PM | Can't see analytical properties
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Elements made by a version of REVIT before these properties where available ?
Mon, Mar 4, 2013 at 4:43:04 PM | Can't see analytical properties
stjern
I use Revit 2013 but the project was made in april 2010 so it had to converted to current version. I just don't understand why these properties are disabled.
Mon, Mar 4, 2013 at 4:48:30 PM | Can't see analytical properties
stjern
I attached a screenshot to explain. When I make my own project these values are shown. Also when I change to another material in the wall for example I can't see the R and U values.
Mon, May 5, 2014 at 11:53:05 AM | Can't see analytical properties
palowe
Have you found solution for this? I have the same issue.
thanks,
Deactivate Analytical Truss and Slab
Wed, Feb 9, 2011 at 8:10:57 AM
Analytical Line
Tue, May 23, 2006 at 6:00:19 AM
Adjusting the analytical line in a revit family
Fri, Mar 5, 2010 at 9:16:31 AM
Analytical Modeling Issues
Wed, May 14, 2008 at 12:03:15 PM
Analytical Model Lines
Fri, Dec 9, 2005 at 5:15:24 AM
Page generation time: 1.6972
