Forums >> Revit Building >> Technical Support >> PDF Artefacts!!
Fri, Jan 27, 2006 at 8:28:36 AM | PDF Artefacts!!
elvis
hi all,
the created pdf's do have a text that is not nicely horizontally aligned, all letters are dancing floating and what ever, even some letters dissapear!
like when i have a template drawing sheet with a titleblock in it [which i put by the project information] it even misses letters, instead of a double T [tt] it prints only one T, can it be thet font or...
E
Fri, Jan 27, 2006 at 11:54:23 AM | RE: PDF Artefacts!!
quiller
quiller Avatar
2.5 Stars: 3 Votes
can you post a sheet or drawing to show what you mean
Sun, Jan 29, 2006 at 11:06:49 PM | RE: PDF Artefacts!!
eldados
eldados Avatar
4.5 Stars: 8 Votes
could be the fonts you are using... what PDF driver do you use?
Integrator
KarelCAD
REVIT 2011 TO PDF FROM CUTE PDF PROBLEM...BLACK BORDER AROUND??
Thu, Nov 4, 2010 at 9:43:22 AM
PDF File Names
Thu, Apr 7, 2011 at 8:37:37 AM
pdf print
Thu, Sep 25, 2014 at 6:04:04 PM
pdf
Sun, May 7, 2017 at 5:12:30 AM
11
Print to PDF
Fri, Jan 23, 2015 at 6:47:45 AM
Page generation time: 0.3329
