80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> updating a revit arch model error (REVIT 12)
2 Posts No Rating |
Hey all,
Ok, i am working on a project in REVIT MEP 2012 and recently got an updated architectural model. I went about the "cleaning up proces" (detaching from central, purging unused, etc.) like usual and saved it over the previous arch model. Now, when i try to open up my MEP Central file, it gives me an error that causes me to either save a recovery file or cancel the load. And when i try to open the recovery file to fix whatever corruption is going on, it gives me the same error message. I even tried opening the MEP Central file and forcibly telling it to read the file from a seperate location, but to no avail. Luckily i can revert back to the previous arch model and everything in my MEP Central seems to be fine. I can open the arch model by itself with no problems besides it being a little slow due to the size of the model, its just when i try to link it in with the MEP Central.
Any ideas whats going on??
Thanks
Here are some facts you must know.
There is no need to "clean up" a linked model. Linked means just that - linked. The linked model size doesn't really matter - only the model elements really contribute to your operation and then even, not to your file size.
Don't save over top the old model. Save it with a new name - we add a date - and use reload from then pick your new file.
2 Posts No Rating |
Thats just how i was informed to do things when i started working at my company with saving over the previous arch model, due to revit providing the backups/previous versions in te folder just with a .0001, .0002, etc. is it better to do it the way you said? I did try to link it in using the reload from option and i still got the same message
Edited on: Fri, Mar 1, 2013 at 1:59:03 PM
You tried the reload from - the model you did not clean up? If so, then that model may be corrupt - even though you can open it.
And you are not linking it correct? The link already exists in your model so you just manage links and use reload from.
updating model |
Mon, Aug 5, 2013 at 8:59:53 AM
Updating Central file (multiple users) |
Fri, May 15, 2009 at 11:44:33 AM
revit 2009 error message |
Fri, Sep 3, 2010 at 8:23:07 AM
Revit error messages |
Wed, Jan 21, 2009 at 6:41:48 PM
Cannot see arch object when model is linked into revit structure from revit arch |
Fri, Jan 22, 2010 at 9:58:53 AM
11
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
