47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dwg export: revit 2013 ignoring subcategories
Fri, Mar 1, 2013 at 11:30:33 AM | Dwg export: revit 2013 ignoring subcategories
maxpower
Hi all,
I'm having an issue with DWG export that I'm hoping has a simple solution:
I've been trying to set up the dwg export setup to match the old office cad standard - having assigned layers to the individual subcategories of a wall type, - I find they don't export as specified and are all assigned the parent category layer - is there a setting somewhere to have revit pay attention to the subcategories? is this a known problem or just my software?
painful friday afternoon issue.
any help will be greatly appreciated!
am working with revit 2013 on windows 7
Wed, Jul 24, 2013 at 2:18:36 PM | Dwg export: revit 2013 ignoring subcategories
trozicki
I am having the same issue, but I can't see a solution, there doesn't appear to be an option to specify different sub categories.
If you ever resolved this issue, please post your solution.  Thank you.
Wed, Jul 24, 2013 at 6:02:29 PM | Dwg export: revit 2013 ignoring subcategories
maxpower
Hey yeah so what I figured out- that is to say that I didn't resolve it - the problem is, if its the same as yours, is that revit calls the edges between the layers of a wall 'common edges' rather that specifying what they are- which I guess means that they avoid developing a hierarchy for layers in a wall make up. I had thought to outrun this by splitting into parts but then revit calls all that parts which is inconvenient. So one work around that might work which I didn't try would be to model each layer in your wall as a different wall. Not at all useful but hey, it's a thought. You get any further?
Thu, Jul 25, 2013 at 8:12:43 AM | Dwg export: revit 2013 ignoring subcategories
trozicki
With your extra information, I can see that my exporting issue was somewhat different: I wanted to assign different layers to subcategories of Room Fills (so that each fill colour went onto its own layer).  I posted a different thread on this topic, but I was told that it is not possible to add subcategories to the room fill layer.  Thank you for your follow up.
Subcategories for export
Wed, Jul 26, 2006 at 12:46:16 AM
REVIT 2013 - Export DWG Layers Text File Location
Fri, Aug 3, 2018 at 4:44:52 PM
Export for VIZ, or anything else...
Thu, Jul 20, 2006 at 3:50:31 AM
Subcategories in export layer setup not displaying properly when exported
Tue, Jul 31, 2012 at 10:50:40 AM
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
Page generation time: 8.0881
