79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Properties of Linked Models
Fri, Mar 1, 2013 at 9:49:18 AM | Properties of Linked Models
Limart
I am still a total noob, but plowing along on my own. I am working in a project that uses six linked models that are updated frequently. With each update, I need to reload them into my model and review what has been changed. I have not delved very deeply into copy/monitor and coordination tools, as my equipment is less grid driven than "did-they-move-the-door-again?" and "why-did-that-wall-turn-into-a-window?" conditions. Most of the time, a good review of each room is sufficient. However, on the occasion that I find a line appearing in a room that I don't recognize and looks suspiciously like new structure, I am wondering if there is any quicker way to determine what that line or object is besides opening (and unloading) the linked model and navigating through it to find that very level, room and object? Sometimes, when I go to the base model, the object is not visible, and I have to hunt through the visibility settings in order to recreate what I'm seeing in my model. Does this make sense?
Fri, Mar 1, 2013 at 10:20:29 AM | Properties of Linked Models
This is why we use copy - monitor.  It is not just for Grids.
You can always tab select elements in a linked model to identify what they are.
You do not have to unload a model to look at it.  If you want to look at it in the same session, save another copy with a unique name and open it up side by side.
Fri, Mar 1, 2013 at 10:34:25 AM | Properties of Linked Models
Limart
Tab select is exactly what I was looking for, thank you.
I get that copy/monitor is meant for other things, but I'm going to need more time to work with it on my own. I tried to use the tool at an earlier stage but was unable to manage it without more experience.
Material Properties for Rendering Linked models- RAC2009
Wed, May 21, 2008 at 9:26:13 AM
View Filters and Linked Models
Tue, Mar 28, 2017 at 7:53:32 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:23 PM
Linked Model - Losing only some doors from linked model
Thu, Oct 21, 2010 at 1:52:15 PM
Linked Models - Element / Component Identification
Tue, Dec 7, 2010 at 4:10:56 PM
Page generation time: 2.6426
