66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Steel beam to steel/concrete column fixture (Noob question)
Wed, Feb 27, 2013 at 1:12:03 PM | Steel beam to steel/concrete column fixture (Noob question)
URZAIZ87
4 Stars: 1 Votes
Hi there, I'm using revit architecture 2013, it's supposed to have revit structure integrated with it right?
We'll if it doesn't we know the problem right from the start.. lol
Still, my question:
I'm learning how to make the structure design in a testing project and i'm using universal steel "I" columns and beams, but when i'm mixing it with concrete columns it's supposed to use a steel plate on the column to weld the steel beam to it. I don't know where or how to create or put that plate.
Any sugestions?
Do i have to model as something else the plate and insert it or is there any specific task revit can do? I saw in a video on youtube some guy using extensions to do this but i don't know where did he get those extensions cause i can't even se the ribbon he picked on my own revit.
Link to youtube video:
http://www.youtube.com/watch?v=u-AGJeMCfhY
Sorry if this is a newbie question, still learning...
*Image attached.
Wed, Feb 27, 2013 at 1:35:08 PM | Steel beam to steel/concrete column fixture (Noob question)
URZAIZ87
4 Stars: 1 Votes
Anyone...??
Wed, Feb 27, 2013 at 2:00:52 PM | Steel beam to steel/concrete column fixture (Noob question)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Revit Architecture 2013 does not have Structure it is just architecture.  There are some structure commands but its not structure.
Wed, Feb 27, 2013 at 2:03:18 PM | Steel beam to steel/concrete column fixture (Noob question)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would not model steel connections unless you really need to see it in 3D.  I would just use detail components for this in a drafting view.
Wed, Feb 27, 2013 at 2:06:13 PM | Steel beam to steel/concrete column fixture (Noob question)
URZAIZ87
4 Stars: 1 Votes
Hmm.. that's half true since i just checked and it's supposed to include in building design suite all structural functions even analytical model. I just found this site in autodesk with the extensions i was looking for, you just install it and when you open revit the extensions ribbon shows with a "steel connections" just like in the vid i linked above.
https://students.autodesk.com/?nd=revit_extensions
Wed, Feb 27, 2013 at 2:44:17 PM | Steel beam to steel/concrete column fixture (Noob question)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"revit architecture 2013, it's supposed to have revit structure integrated with it right?"
WRONG- Revit architecture is Revit architecture and does not include Structure or MEP. The building designe suite DOES include architectural, MEP and structure.  There are a lot of different add-ons for Revit that you can apply.
You asked how to model the steel plate connections.. my answer is still I WOULD NOT model them unless absolutly necessary, I would just use detail components for this.  If you model every connection it is going to bog down your computer.
Wed, Feb 27, 2013 at 3:18:11 PM | Steel beam to steel/concrete column fixture (Noob question)
URZAIZ87
4 Stars: 1 Votes
Hmm, interesting. I installed the design suite and i don't seem to have any other revit than the architectural one.. but the architecture has the structure an MEP ribbons as well as the libraries. I downloaded the extensions and it works with steel connections but it doesn't for concrete-steel.
I get it, you'd rather make a plan with the detailed conection, i'd do to if that was the case, but what i want is to show on 3d model the detailed join between those two (concrete column-steel beam)
Here's the image of how i solved the steel only conections.
revit steel questions
Mon, Apr 6, 2015 at 9:27:21 AM
Lineweight of steel column in coarse view
Fri, Jan 7, 2011 at 6:25:49 PM
Concrete pad footing moves with steel column
Thu, Dec 12, 2013 at 10:58:08 PM
Aligning top of column to top of beams that are set out by bottom of steel
Thu, Dec 12, 2013 at 12:35:42 PM
how to steel concrete floors?
Wed, Jul 1, 2009 at 9:25:02 AM
Page generation time: 0.5547
