30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 'Inconsistent units" error in parameter formula; length vs integer
Tue, Feb 26, 2013 at 12:41:17 PM | 'Inconsistent units" error in parameter formula; length vs integer
enmaso
Hey All,
Im on REVIT2013.
I have this formula that I have written based on the parameter unit type; length vs integer.
Can someone help in "neutralizing the units", so I dont get the inconsistent error? Neutralizing requires dividing or multiplying a parameter by 1. I have treid a dozen options with no success.
(Length - (Length * Integer)) / Length) * Integer = Integer
or aka
(Row Length-(Aisle Width * # of Aisles) / Seat Width) * Rows = Seat Count
Thanks
Erik
Tue, Feb 26, 2013 at 1:03:54 PM | 'Inconsistent units" error in parameter formula; length vs integer
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Since the result is an integer, each one of the length parameters in the formula need to be (Length/1') if it is imperial units, or (Length/1m), for example, if it is metric.
Planta1 Revit Online Consulting | info@planta1.com
Tue, Feb 26, 2013 at 2:28:28 PM | 'Inconsistent units" error in parameter formula; length vs integer
enmaso
Thanks.
I got it to work as such.
(((Row Length / 1) - ((Aisle Width / 1) * (# of Aisles / 1))) / (Seat Width / 1)) * (Rows / 1) = Seats
in normal language the intent of the simple equation is such ...
(Row Length-(Aisle Width * # of Aisles) / Seat Width) * Rows = Seats
Tue, Feb 26, 2013 at 2:38:56 PM | 'Inconsistent units" error in parameter formula; length vs integer
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Glad it worked, but it seems to me that you are simply dividing everything by 1 without thinking of the units. Why did you divide by 1 also the integer parameters if the result is an integer?
Fri, Dec 13, 2013 at 4:21:10 PM | 'Inconsistent units" error in parameter formula; length vs integer
Gehrys
So im trying to get a result of Amps from the Volts and Watts parameters.  Ive tried to neutralize the units with " (Watts / 1) / Volts " but still get the inconsistent units error.
Any ideas?
PS - I know the image shows watts * volts which is wrong, but still wont run the formula.
Edited on: Fri, Dec 13, 2013 at 10:30:35 PM
Fri, Dec 13, 2013 at 10:37:05 PM | 'Inconsistent units" error in parameter formula; length vs integer
Gehrys
Ok, got it.....
(Watts / 1A) / (Volts / 1A)
Inconsistent units
Wed, Aug 11, 2010 at 8:17:27 AM
Inconsistent units workaround
Wed, Jun 22, 2005 at 7:52:55 AM
Parameter Formulas
Wed, Dec 21, 2005 at 2:02:47 PM
The Bane of Formulas - Inconsistent Units
Wed, Jul 2, 2014 at 4:39:37 PM
Array Formula error
Thu, Jul 3, 2008 at 5:23:09 PM
Page generation time: 1.6290
