40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2012 crashes applying wall sweeps
Tue, Feb 26, 2013 at 1:15:38 AM | Revit 2012 crashes applying wall sweeps
Pele
Pele Avatar
I am trying to apply a wall sweep following a video tutorial. But it will not let get past the point where I select apply the sweep, see attached screen shot.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Tue, Feb 26, 2013 at 7:44:25 AM | Revit 2012 crashes applying wall sweeps
Correction, you are trying to redefine a wall by adding a wall sweep.
The problem is probably somehow affected by an instance of this wall already in the model.  If that is not the case, then we need to see more of your process that you have hidden in that pdf.  Also what the profile is like.
Tue, Feb 26, 2013 at 6:23:07 PM | Revit 2012 crashes applying wall sweeps
Pele
Pele Avatar
OK here are a couple of more images as you asked. A screen shot of the profile & a screen shot of the profile made from a profile family template.
Cheers Dermot
www.dmbd.net
Tue, Feb 26, 2013 at 9:43:56 PM | Revit 2012 crashes applying wall sweeps
Pele
Pele Avatar
I have fixed my problem. The profile I created was not a good fit for the wall I was trying to modify, it was way too big. I was following a U tube tutorial & did not give it much thought. So with a profile that was much closer (the correct size for the wall) to the wall in question I followed the steps required to do the job & voila! it worked. And it is good to be able to view it in the viewer when one is adding the sweep to the wall. thanks Hub for your reply to my query.
Cheers Dermot
www.dmbd.net
Revit 2012 crashes at splash screen HELP!!!
Fri, May 17, 2013 at 1:13:25 PM
2012 Wall sweeps exporting problems
Fri, Jun 3, 2011 at 10:48:51 AM
Revit 2012 Crashes Random but everyday [ 1 2 ]
Wed, Feb 29, 2012 at 1:15:58 PM
15
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:42 PM
In-Place Family sweeps issue
Tue, May 15, 2007 at 4:56:51 PM
Page generation time: 1.9989
