83 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Missing Icons in Revit Arch 2013
Sun, Feb 24, 2013 at 1:29:04 PM | Missing Icons in Revit Arch 2013
Wadedrafting
I've just uploaded the 2013 version and as I started a project I started noticing I'm missing certain icons.  For instance these are the 3 I have noticed so far.
Edit profile icon after clicking a wall in elevation view
Check mark after creating floor
Upload families when clicking doors or components
I have already ran a repair in my add/remove programs, nothing has changed.  Please help
Mon, Feb 25, 2013 at 7:31:32 AM | Missing Icons in Revit Arch 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you downloaded all of the service packs?
Mon, Feb 25, 2013 at 5:29:54 PM | Missing Icons in Revit Arch 2013
Wadedrafting
Yes, I imported a project I have been working on from my work computer and now the options are there.  I'm not sure what the glich was but it repaired itself.  Thanks for the reply.
Tue, Jun 4, 2013 at 11:08:37 PM | Missing Icons in Revit Arch 2013
JDAGEN
I have uprgraded to service pack 2 and I am still having problems. currently my 'Architecture' panel is missing and I cannot get it back. Really AutoDesk? Instead of rolling out my acessory programs, how about completing Revit and making it stable.
Wed, Jun 5, 2013 at 7:34:41 AM | Missing Icons in Revit Arch 2013
99% of the time, errors are user errors (although there are installation problems.)
It sounds like YOU do not have your settings set correctly.  2013 is different than earlier releases because it is combined and therefore has addition settings which AUTODESK does tell you about but you must have missed.  Under the Revit R pulldown / options tab, go to the user interface tab and check the boxes for the menues you wish to have.  Your architecture is not checked.
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:19 AM
Missing RCP
Fri, May 17, 2013 at 5:21:25 AM
11
Modifying Revit Button Icons....is it possible?
Tue, Dec 10, 2013 at 11:25:57 AM
Need Help with Revit Arch. 2013
Wed, May 22, 2013 at 10:17:51 AM
revit arch 2013 my 3d views are transparent???..
Mon, Mar 25, 2013 at 7:45:26 PM
Page generation time: 1.9225
