20 Users Online (19 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimension String Question
Sun, Feb 24, 2013 at 11:20:22 AM | Dimension String Question
C3POjr
In a string of dimensions, is there a way to suppress dimensions smaller than a set length?  I am drawing floor plans and want to be able to create a continuous dimension string by editing/adding to witness lines, and not have a dimension for a wall thickness. I just want it to show tick marks on either side of the wall. This is for an owner who wants to see only the clear dimension of rooms.
Thanks in advance.
Mon, Feb 25, 2013 at 9:27:46 AM | Dimension String Question
You can't do it as a string - sorry.
You could over-ride the wall only dimension and make it a period.
Edited on: Mon, Feb 25, 2013 at 9:28:33 AM
Wed, Feb 27, 2013 at 12:17:25 PM | Dimension String Question
C3POjr
Thanks for the suggestion.
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
Adding a dimension to a dimension string...
Wed, Jul 10, 2013 at 3:42:09 PM
dimension string problem
Thu, Oct 18, 2007 at 1:21:31 AM
Dimension String
Wed, Nov 22, 2006 at 3:05:15 PM
partially obscurred dimension string
Mon, Oct 29, 2007 at 10:45:13 AM
Page generation time: 1.2460
