Forums >> Community >> Newbies >> Any way NOT to render a backround in Revit 2013 ??
7 Posts No Rating |
Every time i render Revit seems to be taking an awful amount of time rendering the background. I am now rendering interior and i need no background but i cannot find the option to render with no background. It just takes hours to reach 50% progress (black screen) and i cannot afford that time. I tried a transparent tif but that did not work either.I just want to know if it is possible to render without a background and if not, what background option /picture type is the quickest to render. Thx
Edited on: Sat, Feb 23, 2013 at 9:24:28 PM
Edited on: Sat, Feb 23, 2013 at 9:26:55 PM
Using a 'Section Box' in the 3D view will help eliminate unwanted rendering.
7 Posts No Rating |
It's not the unwanted rendering i am talking about. I simply don;t want to render a background because it takes too much time for the render to hit 50%. There is no option for no background rendering, just option what to set as background (clouds, color, picture). The option was right there in previous Revit editions.
Edited on: Wed, Feb 27, 2013 at 3:49:57 AM
I am not sure if this will actually help but if you select your background style to be Image and DO NOT SELECT and image just cancel out it will still say your style is Image but there is none selected so it does not render any background.
7 Posts No Rating |
With no image selected the ok button is not active.
Read the rest of my post
"DO NOT SELECT an image just cancel out it will still say your style is Image but there is none selected so it does not render any background."
7 Posts No Rating |
Ok, i tried that, no effect. It actually took 15 seconds longer than a color backround.
Backround image [ 1 2 ] |
Sun, Jul 27, 2008 at 7:12:51 AM
15
Duplicate material still changes original in Revit Architecture 2013 [ 1 2 ] |
Thu, Jan 21, 2016 at 12:03:11 PM
24
Revit 2013 Rendering and Materials |
Sun, Nov 25, 2012 at 1:11:09 AM
problems with Revit 2013 in 3ds Max! |
Fri, Dec 14, 2012 at 4:25:45 PM
13
REVIT 2013 - Not ends render - FULL video memory usage |
Fri, May 10, 2013 at 2:20:36 AM
Members: | 2105144 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
