47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> MODEL TEXT BACKWARDS
Fri, Feb 22, 2013 at 12:04:16 PM | MODEL TEXT BACKWARDS
andy777bennett
in 2013 if i ever pick new host with model text it makes it backwards. it is the most annoying thing in this entire buggy program for me. I don't understand why it wants to do this. it is like it selects the other side of whatever face you place it on. help?
Fri, Feb 22, 2013 at 12:33:41 PM | MODEL TEXT BACKWARDS
Not a buggy program.  You are obviously picking the wrong face.  It is very hard to pick a face on very thin objects.
Fri, Feb 22, 2013 at 1:31:49 PM | MODEL TEXT BACKWARDS
andy777bennett
that exit sign is an inch thick. it is not hard to zoom in and have my cursor on the front of it. I found a fix by making a new, 1/8" thick object in front of the body of the sign and hosting to that. I think it was confused because it only reversed the text when I tried to host it to the front of the sign, and it used to be on the back of the sign.
I have had this happen on many other faces in other projects, too. It is a malfunction with revit. I always have to make a new face with a new object to host to.
Fri, Feb 22, 2013 at 1:43:32 PM | MODEL TEXT BACKWARDS
Upload the family so we can look at it.
I have sometimes had problems picking the correct face but not on a thick object.  You picked the face from the 3D view -right? - not from an elevation view.
Fri, Feb 22, 2013 at 2:02:21 PM | MODEL TEXT BACKWARDS
andy777bennett
i reverted it to how it was. knock yourself out.
Fri, Feb 22, 2013 at 2:07:20 PM | MODEL TEXT BACKWARDS
Like this
Sat, Feb 23, 2013 at 8:52:55 AM | MODEL TEXT BACKWARDS
I didn't have time yesterday so I thought I would explain the process I used.
I open the family and from the 3D view, I set the work plane and picked the extrusion, then simply added the 3D text.
Mon, Feb 25, 2013 at 12:51:11 PM | MODEL TEXT BACKWARDS
andy777bennett
my problem does not lie with adding 3d text. it is with picking a new host. if you still have that file, if you click on your text you made and click pick new host it will not work right on any face other than it's origional one.
Mon, Feb 25, 2013 at 1:50:57 PM | MODEL TEXT BACKWARDS
You don't do it the way you want to!  You do it the way I showed you.  You pick the work plane and then add your text in the family.  This is not a face based family.
You could create a face based family with the text and place that on the face of your sign.  BUT WHY????
From your HELP :
Wikihelp, Updated: 2011-03-31-04:00
Model text is a work plane-based 3D element
^^^^^ NOTE:  WORK PLANE BASED!
Mon, Feb 25, 2013 at 2:42:38 PM | MODEL TEXT BACKWARDS
andy777bennett
I thought model text IS face-based though...
Edited on: Mon, Feb 25, 2013 at 2:44:36 PM
Mon, Feb 25, 2013 at 2:52:12 PM | MODEL TEXT BACKWARDS
In the project, you can selecat a face to make that be your work plane .... but it is still a work plane.
In the family, you can pick a plane or a model element but that is not the same as a face.
Tue, Jul 22, 2014 at 2:59:35 PM | MODEL TEXT BACKWARDS
harv
I have had this "model text" backwards problem repeatedly. When I create a "generic model" family in Revit 2014 and then try to place model text on the face of the extruded element, it always comes in backward. I ususally fix the problem by rotating the text 180d or by setting the workplane to a named reference plane, instead of making the face of the extrusuion as the work plane, as would be easier, but this brings on the backward text problem.
Can anyon esle verify that this is a problem?
Any thoughts?
Tue, Jul 22, 2014 at 4:04:09 PM | MODEL TEXT BACKWARDS
#13
I can't get backwards model text except by doing something screwey like picking a workplane in 3D view then rotating the 3D view to the other side.  So, please show us your process and if it is in a family - give us the family.
BTW - you don't say what Revit and what updates installed.
Fri, Jul 25, 2014 at 10:54:14 AM | MODEL TEXT BACKWARDS
#14
harv
Apologies for not being thorough. I am using Revit Architecture 2014 Build 20131024_2115(x64)
Update Release 2. I have been able to reproduce this problem regularly so I beleived others would be able to as well.
The process is simply open a Generic Model template to create a generic model family, create an extrusion by drawing a rectangle with the sketching tool, complete the extrusion. Open in 3D view and set the workplane, by using the "Pick a plane " option, to the front face. Then create model text and attempt to place it on the front face. It comes in 180d reversed.
Fri, Jul 25, 2014 at 10:56:34 AM | MODEL TEXT BACKWARDS
#15
harv
Here is the family I created in the process of confirming the steps I went through
Accidental Backwards Model Text
Fri, Jun 5, 2020 at 11:59:29 PM
Model text
Wed, Jun 29, 2016 at 11:03:18 AM
Model text subtractions
Thu, Jan 15, 2009 at 12:33:33 PM
missing text
Thu, Dec 19, 2019 at 3:35:19 PM
family views backwards
Tue, May 14, 2019 at 3:10:26 AM
Page generation time: 3.0060
