64 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> stair nosing
wehn i give a nosing profile why does it change my treads from slanted to straight? is there a way to have a square nosing profile with slanted treads?
yes, there should be no difference, I can have a profile with straight or slanted...
anytime i give the tread a profile it changes the riser to straight. it still says slanted but the appearance is obviously is staright. could someone please help to fix this? what profiles are you using? i am thinking it may be the profile i am using was created incorrectly and is causing this problem.
Stair Nosing |
Fri, Dec 2, 2016 at 2:01:57 PM
Stair Nosing Profile Help |
Thu, Feb 21, 2008 at 8:29:59 AM
Monolithic Stair Radius nosing? |
Fri, Jan 30, 2009 at 2:10:43 PM
Simple Stair Nosing error |
Thu, Mar 5, 2015 at 9:15:24 PM
Stair nosing |
Mon, Jan 23, 2012 at 2:27:10 PM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
