57 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Door knob misplaced in plan view
7 Posts No Rating |
I successfully added a door knob to door family. It displays perfectly in 3d and elevation but it does
not stick to the door panel (door opened) in plan view.
Question: In 3D your door is opened like you have in that image? Because if it looks "perfectly in 3D and elevations" thats because is closed, correct?
Solution: Edit your family and change the "visibility" of that "Knob" to don't show in plan then create symbolic lines to draw that in the right position like you want.
7 Posts No Rating |
Yes they are closed. I am being new to the program, don't even know how to set them open in those views yet so to check
if there might be the same problem.
I will try what you said and be right back with an answer. Thx.
7 Posts No Rating |
And it worked. Thx.
Edited on: Fri, Feb 22, 2013 at 8:14:27 AM
DOOR KNOB ISSUE |
Thu, Feb 13, 2014 at 8:54:51 PM
Door Knob |
Mon, Mar 23, 2009 at 6:43:20 PM
Problem with door changing in 3D view |
Mon, Jun 25, 2007 at 11:29:09 AM
DOOR TAG QUESTION |
Fri, Mar 1, 2013 at 7:32:19 AM
Room tags, floor marks etc. misplaced in the mirrored plan |
Wed, Aug 29, 2018 at 2:37:35 PM
Members: | 2022252 | Objects: | 22975 | Forum Posts: | 152202 | Job Listings: | 3 |
