109 Users Online (108 Members):
Forums >> Revit Building >> Technical Support >> Revit Window Families
3 Posts No Rating |
Created a window family which I then placed into my project. Need a door within that window family but do not want to modify actual family because it shows up in other places where I do not need door. Any setting I can change that will make revit recognize my window as a curtain wall where I could add a glass door into it?
Thank you!
Jessica Soberanes
You can edit the window family and add the door then save it as a new family - then load it. Now you can use both families.
Will the door schedule seperate from the window as a door with a transom or sidelite? Or will the window schedule as a window? This makes a difference on how the family is created.
window families |
Mon, Nov 28, 2005 at 6:43:56 PM
Window families and revit 2011 |
Tue, Jan 10, 2012 at 11:08:25 AM
WINDOW FAMILIES |
Thu, May 24, 2007 at 5:46:09 PM
Building Families - Window (Single Hung Sector Top) |
Fri, Dec 7, 2007 at 12:19:44 PM
Better Window Families |
Tue, Aug 30, 2005 at 4:25:33 PM
Members: | 2017305 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
