89 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Swimming Pool rendering with dark edges
Thu, Feb 21, 2013 at 6:50:42 AM | Swimming Pool rendering with dark edges
sverhss
Hi,
Does anyone have any idea why my swimming pool is rendering with dark edges? I have tried creating a floor and adding water
as well as creating the water as a mass, it always renders with these dark edges.
Thank you!
Thu, Feb 21, 2013 at 7:15:48 AM | Swimming Pool rendering with dark edges
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would assume its the way the exterior sun lighting is affecting the material.  Wouldn't you have a wall around the edges of water anyway?
Thu, Feb 21, 2013 at 8:07:07 AM | Swimming Pool rendering with dark edges
sverhss
Thanks!
The water is meant to be overflowing into each pool, like a waterfall. I think it is a lighting issue.
Thu, Feb 21, 2013 at 5:57:52 PM | Swimming Pool rendering with dark edges
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
try making the water the thickness it would actually be if you are trying to get that effect I have designed several pools like that and the water thickness will not be much more than 1/4"
Fri, Feb 22, 2013 at 7:49:39 AM | Swimming Pool rendering with dark edges
The pools need walls.  Then if they are to "overflow, the pool water needs to be slightly higher and you need someting else around the edges to look like falling water - not the same as the pool water.  Look at some of the fountains.
How to make a Swimming Pool?
Wed, Sep 28, 2016 at 1:23:06 AM
Swimming Pool
Tue, Dec 8, 2009 at 4:11:29 AM
swimming pool
Wed, Sep 15, 2010 at 12:54:02 AM
Swimming Pool
Tue, Jun 28, 2016 at 9:04:20 PM
Swimming Pool
Mon, Jan 28, 2013 at 7:44:58 AM
Page generation time: 0.4517
