67 Users Online (66 Members):
Forums >> Revit Structure >> Technical Support >> Revit Structure 2013
3 Posts No Rating |
Im working on a project in Revit Structure 2013 that has a large AutoCAD 2012 file linked as a background. I find that as I zoom in and out that the linework of the AutoCAD file contorts and moves with each scroll of the mouse wheel. In AutoCAD the background looks and preforms fine.
I have tried:
- Updated my Driver
- Unstalled and reinstalled
- Unchecked "Use Hardware Acceleration"
- Checked "Anti-Aliasing"
Itsd worth noting that I do get a warning in my Graphics options:
Newer video card driver:
The installed video card driver is newer than those certified by Revit. Card: NVIDIA Quadro 4000; current driver: 9.18.13.1115 Certified drivers: 8.17.12.6570You may continue to use Hardware Acceleration.If you experience graphics display issues, you should: - Turn off Hardware Acceleration; or - Install driver that is recommended for use with Revit
But a co-worker gets the same warning without the graphic issue. I've tried my company IT and other co-workers and were at a loss... so I bring my issue to the boards.
Attached is an example, thanks in advance for anny support
Mike Smith
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Did you try turning off / on Hardware Acceleration in the REVIT > Options > Graphics > Graphics Mode.
3 Posts No Rating |
yes, I unchecked Hardware Acceleration, restarted revit completely, and still had the issue.
![3.5 Stars: 396 Votes](/images/stars_3.5.gif) |
I believe this problem is typically caused by view scale. I think Revit treats the import as one object controlled from its insertion point, not individual line entities. In essence, it may be pixalating the DWG and that causes the jump. Change your overall view scale bot ways and see what happens.
3 Posts No Rating |
I gave changing the scale a shot with no luck. I cant imagine it be a "pixalating" or that thats how linked DWG files work. Id imagine we would see quality loss on a regular base if that was so.
I did however have luck with purging out unneeded data in the background file. Being a Site plan it had plenty of information and line work I did not need. Once I get the file down to a less crowded format it seemed to fix the issue. At first glance id say that my video card couldnt handle to load?
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
I've had this same issue in the past and what I do is; open the cad drawing and turn on all off layers and thaw all freezed layers and then deleted them all and then purge the dwg and then save as. this should correct your problem.
That is a bazaar solution to a graphics problem.
Revit Structure 2013 windows 7 & windows XP Compatibility |
Wed, May 15, 2013 at 1:27:10 PM
Linked CAD ducts/pipes not showing up in Revit Structure 2013 |
Fri, Jul 10, 2015 at 8:36:42 AM
13
Connection Design now available in Revit Structure 2013 |
Thu, Jun 28, 2012 at 8:08:23 AM
Visibility Graphics/Overrides COMPLETELY grayed out. Revit Structure 2013. |
Tue, Mar 27, 2018 at 3:22:42 PM
Revit 2013 - File Structure Standards Multiple Users |
Mon, Mar 4, 2013 at 12:09:14 PM
Members: | 2080327 | Objects: | 23122 | Forum Posts: | 152264 | Job Listings: | 3 |
