46 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Mirror stairs has different layout
Tue, Feb 19, 2013 at 8:24:52 PM | Mirror stairs has different layout
bonchaws
I am modeling a front entry with a circular stair that comes up both sides of the landing.
I used the mirror tool to create the set of steps coming up on the opposite side and come up with a slightly different set on the mirrored side.
The original side has the last tread below the landing, the mirrored side has the last tread level with the landing.
Another problem is that the newel post I am using stands higher on the mirrored side that the oringal.
I have deleted the one side  with all the attached walls and landings and mirrored the thing over and over,
Always get the same outcome.
What is going on??? Can anyone help me?
Thanks
Wed, Feb 20, 2013 at 5:20:12 AM | Mirror stairs has different layout
sagarlondonites
Make sure instance properties of both the stairs are identical - i.e. Base Level, Top Level, Offsets from Level etc.
Edited on: Wed, Feb 20, 2013 at 5:20:39 AM
Thu, Feb 21, 2013 at 7:19:40 PM | Mirror stairs has different layout
bonchaws
I made sure they were all the same.
still same outcome.
Fri, Feb 22, 2013 at 3:24:42 AM | Mirror stairs has different layout
4 Stars: 203 Votes
Images please... Sorry but I'm not figuring out what's the issue...
mirroring problems
Tue, Sep 14, 2004 at 12:04:27 PM
using the mirror comand [ 1 2 ]
Thu, Oct 15, 2009 at 9:13:36 AM
17
HELP... need to mirror a plan
Wed, Jul 2, 2008 at 12:27:55 PM
12
Mirror Material in Revit not Working
Tue, Sep 23, 2014 at 5:49:41 AM
how to mirror a family
Wed, May 26, 2010 at 4:09:25 PM
Page generation time: 0.2917
