96 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Curved Walls with Openings
Tue, Feb 19, 2013 at 6:39:31 PM | Curved Walls with Openings
annabeans
I am working on a project that involves using curved walls vertically, like so ( . I am trying to insert an opening into them and cannot seem to do it without exporting the wall into AutoCAD Fusion. I Was wondering if anyone knew of a way to do this?
Wed, Feb 20, 2013 at 3:32:15 AM | Curved Walls with Openings
4 Stars: 203 Votes
You can create a Window family where you have only the hole, or a Face based family... No need of Autocad Fusion
Tue, Feb 26, 2013 at 11:20:34 AM | Curved Walls with Openings
annabeans
Revit won't let you bend an object like that in order to make it curved to the wall i am using. Any other ideas?
Tue, Feb 26, 2013 at 12:26:33 PM | Curved Walls with Openings
4 Stars: 203 Votes
Images please.
Tue, Feb 26, 2013 at 12:35:39 PM | Curved Walls with Openings
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
What about just adding an in-place void extrusion etc . . . ?
Curved wall openings
Fri, Oct 15, 2010 at 12:42:12 AM
Openings on a curved roof
Sat, Jul 25, 2009 at 2:35:50 AM
Problems with Curved Walls and Masses
Thu, Mar 20, 2008 at 12:09:02 PM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:29 PM
Cutting irregular openings in curved walls
Sun, Apr 9, 2006 at 7:45:40 PM
Page generation time: 3.1994
