95 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair Riser/Tread Number in Multistory Stairs
Tue, Feb 19, 2013 at 9:13:56 AM | Stair Riser/Tread Number in Multistory Stairs
rafzao
Hi!I'm trying to use the Tread Number tools on a multistory stair but it only works in the first floor, the option to define the Tread Number don´t appear in the other floors where the stair is copied.Anyone knows how to solve this?
I'he attached an image showing what´s is going on... The stair is set to go to the Level 1 to Level 2, and Multistory to Level 4.
Thank you.
Rodrigo
Tue, Feb 19, 2013 at 10:25:48 AM | Stair Riser/Tread Number in Multistory Stairs
3.5 Stars: 395 Votes
What do you mean by: "... the option to define the Tread Number don´t appear in the other floors where the stair is copied..."?
Muti-story stairs are not copied floor to floor.
Did you follow the process as outlined in your HELP?
Tue, Feb 19, 2013 at 1:50:40 PM | Stair Riser/Tread Number in Multistory Stairs
rafzao
The Multistory is set to Level 4.
I know its not an actual copy, just don´t  know how to name it hehe
Can you use the Tread Number in a multistory stair, not on the first levels?
Fri, Oct 31, 2014 at 9:36:59 AM | Stair Riser/Tread Number in Multistory Stairs
cobblea
I am having the same trouble. The stair that I am using is drawn from Level 2 up to Level 3 with a Multi-Story Top Level at the level 5.  When I try to use the Stair Path tool or the Tread Number tool, I cannot apply either one to the multi-story portion of the stair object.
Fri, Oct 31, 2014 at 10:28:42 AM | Stair Riser/Tread Number in Multistory Stairs
Turn stair path on in VG for the view - annotations.
Fri, Oct 31, 2014 at 12:51:04 PM | Stair Riser/Tread Number in Multistory Stairs
cobblea
Thanks for the idea WWHub.  I checked the VG settings, and the stair paths were all on.  I tried to duplicate the problem in a blank file from our project template (see attached).  The Tread Number tool is able to grab the stair between Level 1 & Level 2, but it isn't grabbing the stairs above that.  A similar problem appears in plan views of Level 2 and Level 3 when I try to use the Stair Path tool.  It seems to be something hard-wired into the program where the portions of a stair object above the original definition cannot make use of the annotation tools.  Unless I am missing something or if there are better ideas, I think I will stick to drawing stairs one level at a time and using Model Groups for similar floors above.
Fri, Oct 31, 2014 at 12:53:50 PM | Stair Riser/Tread Number in Multistory Stairs
cobblea
I think I forgot to attach the file. Hope it works this time:
Tue, Sep 13, 2016 at 9:47:54 AM | Stair Riser/Tread Number in Multistory Stairs
sllana
5 Stars: 2 Votes
2016 and this five thousand dollar programm haven´t fix it yet.
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
Stairs: Hide Tread and Riser in Section View
Mon, Mar 11, 2013 at 8:36:41 AM
Stair riser at floor connection
Tue, Jul 31, 2007 at 11:51:27 AM
Handrail Supports on Multistory Stairs
Tue, Jun 24, 2014 at 3:10:16 PM
Can't creat multistory stair
Mon, Jun 6, 2011 at 12:43:55 PM
Page generation time: 0.4880
