30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revsions & Revision Clouds
Mon, Feb 18, 2013 at 1:15:27 PM | Revsions & Revision Clouds
JohnEdw
Problem adding new revision and new revision cloud:  Checked revision as issued, added new revision tried to add a cloud for new revision and recieved message that cloud can not be added to issued revision.  Expanded error message indicated that an element was deleted a error must be resolved.  The id # for error changes afte each inquiry. What is the issue and what is the solution?
Mon, Feb 18, 2013 at 1:56:11 PM | Revsions & Revision Clouds
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"recieved message that cloud can not be added to issued revision"
You can't add a cloud to a revision that you have already checked as issued.  Click Revision Cloud under the annotate tab then look at your Properties and change the Revision to your NEW revision and not your already issued one
Mon, Feb 18, 2013 at 2:22:58 PM | Revsions & Revision Clouds
JohnEdw
I know that once the revision has been issued that a cloud can not be added.  However, I have created a subsequent revision that has not yet been issued and this I when I get the message that a revision cloud can not be added to an issued revision.  Something is not alowing the added revision to register as being available.
Mon, Feb 18, 2013 at 2:43:29 PM | Revsions & Revision Clouds
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Post an image of your revision dialog box and the error that pops up when trying to create a new revision cloud.
Mon, Feb 18, 2013 at 2:54:05 PM | Revsions & Revision Clouds
Did you copy an existing cloud or draw a new one?
Mon, Feb 18, 2013 at 10:02:26 PM | Revsions & Revision Clouds
JohnEdw
teafoe5, see attached images.  WWHub, I drew a new cloud.
Tue, Feb 19, 2013 at 7:25:43 AM | Revsions & Revision Clouds
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What Revit version are you using?  After digging into it a little bit this is a recognised bug in 2010 (not sure about other version but its not a problem in 2013) so uncheck all the issued revisions before trying to add a cloud then change the revision that the cloud is trying to associate with to the latest revision you are trying to add. Then recheck the issued boxes.
Wed, Feb 20, 2013 at 1:32:13 PM | Revsions & Revision Clouds
JohnEdw
I am using version 2010.  I'll try what you recommended. Thanks
Revision clouds - off on one sheet but not on other sheets - is this possible?
Fri, Mar 16, 2012 at 9:13:39 PM
Revision Clouds
Tue, Dec 18, 2007 at 10:52:44 AM
shading revision clouds Revit 2017
Wed, Feb 28, 2018 at 2:56:28 PM
Revit clouds
Tue, Jul 29, 2014 at 10:43:12 AM
Sheet Issues/Revisions - Previous Revision Clouds Halftone
Wed, Aug 22, 2012 at 11:03:14 AM
Page generation time: 0.4836
