Forums >> Revit Structure >> Technical Support >> Question About Model Pattern
5 Posts No Rating |
I have a shell building that I am trying to add King Size brick too. I want this to show up as a model pattern so it will show up in 3D view, elevation, ect... I know how to properly make a model pattern file in note pad so revit will read it. The issue i am having is that everytime i try to create a new model pattern in revit and assign the .pat file to the new model pattern in revit a dialogue box appears saying "No "Model" type patterns found". I know that i have the model type stated in the notepad .pat file.>;%TYPE=MODEL. Yet it pops up with this error box in Revit. Would like to know if this has happened to others and how to resolve this.
Thanks.
You have:
>;%TYPE=MODEL
and that needs to be:
;%TYPE=MODEL
on its own line.
Edited on: Mon, Feb 18, 2013 at 12:21:00 PM
5 Posts No Rating |
Im sorry that is a typo on my part. I do have the ;%TYPE=MODEL in the text correctly
Why not post your text? At least the beginning.
I believe this line had to be right under the title line and before anything else.
I also don't remember if this error pops up if the file is incorrect elsewhere....
5 Posts No Rating |
*Brick
;%TYPE=MODEL
0, 0, 0, 0, 9
90, 0, 0, 2.75, 0, 4.5, -4.5
Everything appears to be correct. Are you sure this is a simple txt file?
Also ... I wonder - Is this a unique name? Just brick? Could you already have a 2D pattern for Brick????? Just wondering if Revit doesn't like this. Change that and see if it does work.
5 Posts No Rating |
Yes this is a simple text format, i have double checked. The name brick is not unique and i have even tried labelling it in different ways, still recieving the same error message.
5 Posts No Rating |
Nevermind, situation resolved, found the solution and rolling on now.
Please always post what the solution was so that others may learn.
Floor Model Pattern - Model option greyed out |
Fri, Mar 3, 2017 at 10:11:12 AM
Floor pattern not showing up when the pattern is model pattern |
Fri, Nov 3, 2023 at 9:11:59 PM
Model pattern override |
Wed, Nov 10, 2010 at 3:50:54 PM
Model Cut Pattern? |
Wed, Jan 30, 2013 at 12:16:11 AM
Editing Model Patterns... |
Mon, Jan 4, 2010 at 12:56:50 PM
Members: | 2016890 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
