Forums >> Revit Building >> Technical Support >> can't make monolitic stairs
I am trying to create an U stair by sketch but I keep getting the error "Can't make monolitic stairs".
I'm a freshman with REVIT so I am having a difficult time trying to sort this one out.
Can anyone help me?
thanks in advanced.
Joaquim
Using REVIT architecture 2013
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit |
Did you follow the process as shown in your HELP?
Post images.
Strange.
I manage to did it but by using the boundary and risers method. When using the Run it did not work.
Still, haven't learned why and that annoy's me.
Here's the Type Properties. It is just a duplicate from the monolitic stair type with changes in the riser max height.
ArchiCAD 16 Win
Vê o video (watch the video): http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0505-Stair_by505
e estes tambem (and these too): http://wikihelp.autodesk.com/Revit/enu/community/videos/004_Architectural_Modeling/Stairs_and_Railings
Edited on: Mon, Feb 18, 2013 at 9:41:38 AM
Obrigado pelos links para o Help.
Noutras pesquisas que fiz encontrei pessoas dizendo que as escadas devem ser dos objectos mais complexos do Revit. Fiquei mais descansado e justificado na minha frustração.
Abraços.
ArchiCAD 16 Win
Na versão 2013 eles melhoraram muito esta ferramenta (escadas), agora temos a função "Stairs by component", é muito mais facil trabalhar em "stairs" e "Railings"
Um Abraço da Guarda.
E um abraço de Almada.
ArchiCAD 16 Win
hole in the second level for stairs? |
Fri, Apr 24, 2009 at 9:42:59 PM
Curved monolitic stair won't generate in 3d |
Tue, Mar 6, 2012 at 8:52:05 AM
Need help with stairs |
Thu, Feb 9, 2006 at 2:35:54 PM
Stringer |
Mon, Jul 21, 2008 at 12:41:11 AM
Can't count multi stairs |
Tue, May 14, 2019 at 1:43:09 PM
Members: | 2115471 | Objects: | 23192 | Forum Posts: | 152305 | Job Listings: | 3 |
