66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> REVIT MEP 2012 Ductwork Connection to Sidewall Diffuser
Fri, Feb 15, 2013 at 7:04:54 PM | REVIT MEP 2012 Ductwork Connection to Sidewall Diffuser
ctrujillo45
Hello there- In some instances, my flexible ductwork will not make a complete connection to a sidewall diffuser/ plenum. It leaves a straight line before showing the flex. I've checked all of the flexible ductwork settings, checked to make sure the ductwork is making the connection at the proper elevation, inserting vertex, etc. Nothing works. The weird thing is it only happens occasionally.
 See attached image....any suggestions?
Wed, Mar 20, 2013 at 3:32:00 PM | REVIT MEP 2012 Ductwork Connection to Sidewall Diffuser
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Weird things happen to duct work (and pipes) when there's not enough room to make a bend or tansition. Not sure if that scomes into play.
Also what is your 'maximum length' set to for flex ducts ?
REVIT MEP, Diffuser Airlfow Parameter isssue
Mon, Jun 21, 2010 at 1:46:23 PM
Using Revit MEP to make ductwork shop drawings
Wed, Jun 15, 2011 at 9:52:03 PM
Revit MEP 2011 sloping ductwork by default?
Thu, Nov 17, 2011 at 3:49:27 PM
2D diffuser transparency
Wed, Jan 8, 2014 at 8:31:37 AM
12
Locking MEP Elements
Tue, May 31, 2011 at 12:52:32 PM
Page generation time: 3.1707
