62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sheet list- sheet no. range
Thu, Feb 14, 2013 at 4:57:40 PM | Sheet list- sheet no. range
vidhikholia
The sheet list I have made for a project is containing more than a 100 sheets. It's having same sheet name with a range of sheet numbers i.e. sheet A1 to A11 are for the same joinery.
Is there any way to generate a sheet list with a range of sheet no. with common name.
i.e. A1 to A11-"same joinery name"
     A12 to A20-"another same joinery name"
Is it possible???
Wed, Feb 20, 2013 at 11:52:29 AM | Sheet list- sheet no. range
ArchAddict
We create two sheet lists, one that goes on to the cover sheet, and another with two additional columns (hidden on the cover sheet version). In one with additional columns we have a sort order column where we enter 1, 2, 3, to sort and group by, and a second column that lists disciplines like "Structural" "Architectural". then on the cover sheet version we can group, add blank lines between groups and use the disciplines column as a title to each group. You could also filter the sheet list by these hidden columns and create as many sheet lists as you need.
Doesn't sounds like Exactly what you want, but should get you going in the right direction.
Ordered Sheet List with Consultants Sheet
Tue, Sep 8, 2015 at 1:27:23 PM
Adding parameters to Sheet List question
Wed, Apr 25, 2012 at 12:09:20 PM
Sheet list
Thu, Feb 28, 2013 at 12:55:16 PM
Multiple independent sheet index for cover sheet
Tue, Feb 4, 2014 at 8:28:14 AM
Filtering placeholder sheets by discipline in a sheet list
Thu, Jun 23, 2011 at 12:27:05 PM
Page generation time: 1.8154
