65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Hip roof framed details - Revit Arch. 2013
Thu, Feb 14, 2013 at 7:58:02 AM | Hip roof framed details - Revit Arch. 2013
robp72
Hi! What is the best method to draw a framed hip roof. I would like to use metal c channel, w shapes, and tube steel to do this roof. I started a new Family to draw the roof but I am having trouble getting some of my steel shapes to work with the angles.Thanks,Rob
Thu, Feb 14, 2013 at 1:12:50 PM | Hip roof framed details - Revit Arch. 2013
4 Stars: 201 Votes
Post some images please so we can see.... You can use the "Beam System" to do that
Thu, Feb 14, 2013 at 2:02:32 PM | Hip roof framed details - Revit Arch. 2013
robp72
Thanks! I attached what I am working on. I am doing this as a family and extruding the steel shapes. The top ridge is a piece of tube steel 10"x3" the rafters are c channel. I am using voids to cut the corners where members join. I am having an issue with the hip, its twisting off axis when I rotate it into place. Any ideas would be great, Thanks again.
Rob
Fri, Feb 15, 2013 at 4:28:21 AM | Hip roof framed details - Revit Arch. 2013
4 Stars: 201 Votes
Yeah, you can use the Beam System and BTW you don't need to use VOID to cut the corners like you said, you have tools  for that OR you can create in a Section / Elevation view a REF. PLANE and then CUT the beam trought the RP.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0735-Structur735/0843-Joins_an843/0855-Beam_Joi855/0857-Miter_Be857
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0735-Structur735/0843-Joins_an843/0855-Beam_Joi855/0859-Creating859
Fri, Feb 15, 2013 at 6:27:06 AM | Hip roof framed details - Revit Arch. 2013
robp72
Thanks! I will give it a try. I appreciate your help.
Take care,
Rob
a pitched hip roof with an arched dormer window and standing metal seam finish
Wed, Nov 13, 2019 at 5:31:44 AM
Hip Roof Issue
Mon, Mar 24, 2008 at 1:30:08 PM
Partial Hip Roof
Tue, Jun 26, 2007 at 3:22:10 PM
host sweep not working in R2009 when roof fascia option used on ridge and hip li
Sat, Sep 26, 2009 at 10:07:00 AM
REVIT Structure and Architecture for wood framed buildings
Thu, Apr 18, 2019 at 2:38:02 PM
Page generation time: 3.1370
