74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> attachig walls to circular stairs
Tue, Feb 12, 2013 at 9:40:40 PM | attachig walls to circular stairs
bonchaws
I am tyring to  model an entry stair system with circular stairs that has an attached wall below. The only way I seem to be able to create a wall below the stairs close to the shape of the bottom side of the  stairs is by creating a reference plane and attaching the wall to the reference plane. The only problem with it is that the only way I know to make the ref. plane for this  is straight on in elevation, so the walls do not perfectly mimic the shape of the stairs because the reference plane is flat and the stairs are not.
Is there an easy way or any way to do this?
using Revit 2012
Tue, Feb 12, 2013 at 11:35:29 PM | attachig walls to circular stairs
mansell5
3.5 Stars: 4 Votes
gday bonchaws,
see link below, bruce gows blog
http://revit-alize.blogspot.com.au/2006/04/below-stairs.html
hope this helps
cheers
geoff
Wed, Feb 13, 2013 at 4:17:33 AM | attachig walls to circular stairs
4 Stars: 203 Votes
This is an old question... Similar threads, bottom of this page!
circular stairs
Mon, Mar 24, 2008 at 4:40:37 PM
Circular Stairs
Thu, Nov 3, 2005 at 5:13:20 PM
circular stairs with spiraling wall around them
Tue, Mar 24, 2009 at 3:58:27 PM
circular stairs
Wed, Mar 16, 2005 at 10:02:03 AM
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Page generation time: 1.5304
