76 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Walls - Paint Layer
Tue, Feb 12, 2013 at 3:42:50 AM | Walls - Paint Layer
alb1no
Hi,
I want to make Paint layer with 0 thickness.
I also want the paint to be shown in my Finish Materials schedule in the Wall Finish column.
Should I make it as a Memrane or Finish Layer in the Edit Assembly?
Tue, Feb 12, 2013 at 4:07:13 AM | Walls - Paint Layer
4 Stars: 203 Votes
Did you tried? and the results are?
Tue, Feb 12, 2013 at 6:29:35 AM | Walls - Paint Layer
Great answer Ty...
Tue, Feb 12, 2013 at 7:44:35 AM | Walls - Paint Layer
alb1no
I've made room which walls have Finish 2 layer set to 5cm. That material is not apearing in the schedule under Wall Finish.
Also another Q: I want my paint layer to cover any columns and beams that are embeded in my wall.
However this layer must have thicknes greater than 0. Should I make thin layer (for example 1cm) to cover them,
and choose paint material?
Ty in advance.
Tue, Feb 12, 2013 at 7:59:06 AM | Walls - Paint Layer
What Ty is telling you is to try out your thoughts yourself.  You will understand it much better that way.  Then come back with your observations.
Paint Walls
Fri, Dec 10, 2010 at 12:02:23 PM
Remove Paint from Walls
Wed, Feb 9, 2011 at 1:33:46 PM
Changing Wall Paint color
Sun, Feb 7, 2010 at 7:02:40 PM
How to apply paint to walls/choose a colour?? (Revit Architecture)
Mon, Nov 14, 2016 at 10:38:53 AM
3d model shows wireframe while in shaded mode
Mon, Oct 3, 2011 at 4:14:53 PM
Page generation time: 3.0993
