61 Users Online (60 Members):
Forums >> Revit Building >> Tips & Tricks >> Creating a Level schedule
2 Posts No Rating |
Create a mass you'll name "Level_01 to Level_02". Lock the bottom surface of the mass with the Level_01 and the top surface of the same mass with the Level_02. The height will be determine by the distance between the Level_01 and the Level_02.
Then make sure the mass is a 1 unit width x 1 unit length. The trick is here... You'll use the "Gross volume" parameter of the mass to get the height between each level. With a mass of 1x1xHeight, the volume will be equal to the height!
Finally, create a Mass schedule with the "Type" and "Gross Volume" fields. Ajust the "Gross Volume" field format to supress the unit symbol.
Voila! you now have a Level schedule that is dynamic with the model.
I have never had to create a level schedule but this may come in handy one day.
Schedule curtain panel by level? |
Fri, Sep 2, 2016 at 4:40:25 PM
sort door schedule by level without adding "level" column? |
Tue, Aug 15, 2017 at 11:27:04 AM
CREATING LEVEL IN NEW PROJECT. |
Mon, Jan 6, 2014 at 10:00:33 AM
Creating a Schedule showing all Assembly Codes |
Tue, May 17, 2005 at 2:48:23 PM
Serious Error when creating Level |
Tue, Dec 16, 2008 at 5:04:05 PM
Members: | 2017168 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
