68 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Missing Revit Library??
11 Posts No Rating |
I'm trying to install Revit 2013 on my home computer. I use Revit 2013 at the office and I want to also work from home. Anyway, I installed the program and there are no families in the library. So, if I want to place a window it asks me to load a window from the library. The library pops up and it is empty. How do I download the standard library that usually comes with the program? I'm not sure how it failed to load with the program. Thanks!
You might have to try to reinstall Revit. Try it with temporarily disabling your firewall this time.
It may be that your Revit pointers are not set correctly. In Windows exployer, search your system for .rvt files. That should find you template files in the library. Look at the path then in Revit, under the Revit 'R' set the paths correctly under the options.
Revit 2009 Web Library |
Wed, May 21, 2008 at 4:13:53 PM
Missing library in Revit 2013 |
Mon, Apr 30, 2012 at 7:57:18 AM
RPC render images missing |
Wed, Nov 24, 2021 at 11:45:42 AM
Missing MEP Library |
Fri, Apr 19, 2013 at 4:10:43 PM
Custom Material Library Problem |
Wed, Nov 13, 2013 at 4:18:49 PM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
