61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Revit 2013 text in coarse scale fill patterns
I am trying to add a pattern to the coarse scale fill within our wall assemblies that displayes STC and FRR requirements
e.g.
0-0-0-0-0 or -stc-45-stc-45- etc. I am able to make a custom pattern with linetypes but I would like text to show
I know how to add a coarse scale fill I cannot find a way to create this as a pattern in AutoCAD to import or ccomplete this in revit.
Thank you
I don't know about the pattern (I'm quite sure is not possible) but you can create that with a "LINE BASED FAMILY"...
Can the line based family be embedded within the coarse scale fill in the wall assembly?
No.
Please see attached jpg. In wall assembly structure material; editor I have assigned a pattern for 2 hour rated wall. instead of showing linetypes I would like the pattern to read -0-0-0-0- or -stc-45-. This is what I am trying to accomplish so the walls read on our 1:50 1:25 plans.
I cannot figure out how to create this pattern.pat file for import
I don't believe you are going to be able to do what you are looking for. You could add a different fill pattern to each wall and have a legend explaining the fill or as Typhoon suggested use a line based family and draw around the walls you need.
http://www.revitcity.com/downloads.php?action=view&object_id=12871
coarse scale fill pattern |
Tue, Apr 29, 2008 at 8:48:54 PM
Topo coarse scale fill color |
Fri, Jun 15, 2007 at 10:00:13 AM
Existing Walls with Coarse Fill Pattern Revit 2008 |
Wed, Aug 13, 2008 at 3:28:01 PM
How to add 'Coarse Scale Fill' parameter to family |
Thu, Dec 15, 2005 at 2:49:21 AM
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
