Forums >> Revit Building >> Technical Support >> Area plan
52 Posts No Rating |
Hi,
I am using desgin option.And i am unable to figure out how to create differnet area plan for same plan but different option.for example i have first floor plan with differnt entrance area,porch,living area for which i have used design option.But i am unable to create area plan for differnt option. i tried using visibility graphics but dint help.
Any methods to create this?
Thanks,
The method you have to do is the following
assuming we have a Flloor plan, duplicate this View
In the first Floor Plan go to the Visibility graphics and turn on option 1 (so change the Automatic setting into your option)
In the duplicated Floor Plan go to the visibility graphics and turn on option 2
Now you can drag & drop both floor plans on one sheet
Hi,
I duplicated the view and changed in the visilibity graphics to option 1 or option 2.I will get plan for that option but not the colour fill.How do i do that?
Thanks,
you will need to create another colour , just name it something else, and use that colour for the other option...
Area Plan does not match Area from Materia/l Area |
Tue, Feb 13, 2018 at 7:50:04 AM
Area from Area plan to show on floor plan |
Fri, Feb 27, 2009 at 7:53:30 PM
Area Plan |
Thu, Aug 7, 2008 at 11:58:57 PM
Disappearing Area Plan |
Fri, Sep 4, 2009 at 12:01:38 PM
Use Area Plan as my Floor Plan? |
Fri, Aug 30, 2019 at 12:31:03 PM
Members: | 2104075 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
