80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> wall placement Revit architecture 2013
Thu, Feb 7, 2013 at 10:18:50 AM | wall placement Revit architecture 2013
omahawildcat
I do not get any difference between selecting "finish face of exterior" or "exterior face of core"
The wall placement when I use the rectangle tool is both located off of the exterior face of core.
Thu, Feb 7, 2013 at 4:30:45 PM | wall placement Revit architecture 2013
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If that is the case then your exterior face is in fact in the 'core' of the wall structure.
Click the wall, then on the properties palette click the 'Edit Type' button then the skinny 'Edit button for 'Structure'. That is where you position the wall layers. You will observe that on the 'Exterior' side the core is at the outer most layer.
Add a new layer and 'move' it outside the core andthen try again. See attached image.
Edited on: Thu, Feb 7, 2013 at 4:32:13 PM
Create in-fill walls under spiral stairs - Revit Architecture 2013 specific
Thu, Jul 7, 2016 at 10:50:48 AM
Revit Architecture 2013 Question
Mon, Apr 23, 2012 at 4:17:41 PM
Using tools in the Systems tab - Revit Architecture 2013
Wed, Sep 19, 2012 at 4:21:08 PM
Revit Architecture 2013 Electrical Circuits
Thu, Jul 11, 2013 at 7:27:01 AM
baluster placement in stairsteps
Thu, Mar 28, 2013 at 7:16:26 AM
Page generation time: 2.4215
