83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Parapet wall sweeps at corners with different wall thicknesses
Thu, Feb 7, 2013 at 9:57:47 AM | Parapet wall sweeps at corners with different wall thicknesses
naterfisher
4.5 Stars: 3 Votes
I have a 520mm wall creating a corner with a 395mm wall, each wall has a different parapet sweep profile to suit the wall thickness. I cannot get these two sweep profiles to mitre correctly. The heights of the walls are equal, the materials for the flashing profiles are equal and the interior/exterior peaks of each profile are equal, still no luck. I have tried creating a custom parapet corner piece using a sweep blend, but have the issue of picking two paths for the sweep blend stopping me as well.
I am using Revit 2012.
Thu, Feb 7, 2013 at 10:16:12 AM | Parapet wall sweeps at corners with different wall thicknesses
3.5 Stars: 395 Votes
There is no "correct" miter.  Two different profiles.  If you want this to be "correctly" modeled, do a special family for this condition and hold your sweeps back accordingly.
Thu, Feb 7, 2013 at 11:00:38 AM | Parapet wall sweeps at corners with different wall thicknesses
naterfisher
4.5 Stars: 3 Votes
Gotcha, I was hoping there was a way to mitre a right angle corner that does not have a 45 degree flashing mitre because the parapets are varying thicknesses. I'd prefer to keep things parametric but I can live with the custom family. Thanks for the advice.
Edited on: Thu, Feb 7, 2013 at 11:03:47 AM
Parapet wall sweeps not joining
Fri, Oct 25, 2013 at 3:00:32 PM
Complicated Wall Sweeps-Need Some Guidance!
Tue, Nov 6, 2007 at 11:22:37 AM
Wall Corners and Joints
Thu, May 9, 2013 at 2:50:52 PM
Wall Sweeps Origins
Mon, Dec 1, 2008 at 5:01:40 AM
wall sweeps
Fri, Aug 19, 2011 at 2:21:16 PM
Page generation time: 2.7443
