109 Users Online (108 Members):
Forums >> Revit Building >> Technical Support >> PATTERNS AND PENS
IS THERE ANY WAY TO SET WHICH PEN WIEGHTS TO PRINT PATTERNS PER THE VIEW YOU ARE IN. I CAN CHANGE THE WIDTH OF LINE WEIGHT ONE, PUT THAT CHANGES MY PATTERN THICKNESS IN ALL MY VIEWS. I JUST NEED IT TO PRINT THICKER IN MY ELEVATIONS. I CAN CHANGE IT PRINT MY ELEVATIONS, THEN CHANGE IT BACK AND PRINT EVERYTHING ELSE. IT JUST IS A LITLE CUMBERSOME TO HAVE TO GO THROUGH ALL THAT TO GET THE DESIRED EFFECT. CHANGING THE COLOR OF THE PATTERNS ONLY WORKS VERY LITTLE, BECAUSE THE LINE WEIGHT IS TO SMALL. WHEN IT IS BUMPED UP THE LIGHTER COLORS OF THE PATTERNS WORKS GREAT. I WAS HOPING I COULD SET THEM TO ONLY PRINT THICKER IN MY ELEVATION VIEWS.
THANKS
Pen 1, color and halftone .... only options. Color and halftone can be set by view or instance.
THANKS,
THAT IS THE CONCLUSION I CAME TO BUT WANTED TO BE SURE I WASN'T MISSNIG ANYTHING. THANKS AGAIN
Line weights |
Fri, Jul 20, 2007 at 5:25:32 PM
Where do model patterns go? |
Thu, Sep 24, 2015 at 9:37:41 PM
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
Material cut patterns |
Mon, Sep 19, 2016 at 8:56:36 PM
No Surface Patterns in Perspective |
Thu, Feb 1, 2007 at 4:55:53 PM
Members: | 2056329 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
