42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 3D GHOST WINDOWS
Wed, Feb 6, 2013 at 10:39:44 AM | 3D GHOST WINDOWS
Roger1w
HI All
I have having a problem in revir 2013 mep.
In all my 3d view i get ghosting of all glass through walss etc. the darker i make  or less transparent i make the glazing the more it shows through walls floors and roofs.
Wether in hidden line or shaded even glazing in doors or curtain walls shows through.
Thank you for your help
Wed, Feb 6, 2013 at 10:50:39 AM | 3D GHOST WINDOWS
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Most likey a graphics card issue.  Update you drivers and it should change.  You can also try turning off hardware acceleration to see if that helps.
Wed, Feb 6, 2013 at 11:06:52 AM | 3D GHOST WINDOWS
Roger1w
that seams to have fixed it
thank you
How to delete Ghost Windows in the Model?
Mon, Apr 28, 2014 at 2:56:19 PM
Windows below only show when Ghost Surfaces is turned on?
Thu, Feb 2, 2012 at 4:44:00 PM
ghost callouts
Wed, Oct 11, 2006 at 7:20:33 AM
Sheet Number Already in Use...I have ghost sheets.
Tue, Nov 21, 2017 at 8:47:10 PM
Revit 2012 to Revit 2016 - Removing Ghost Surfaces Visualization Effect
Thu, Mar 31, 2016 at 10:00:40 AM
Page generation time: 0.4326
