101 Users Online (100 Members):
Forums >> Revit Building >> Technical Support >> Curtain wall system grid angle
2 Posts No Rating |
Hi,
I'm having similar problem like described here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=776&start=15
but it seems like the video is not available anymore.
My problem is as follows:
I'm trying to build a shell around my building that consists of sloped surfaces (planes) of a different shape. I need to divide it to check some design possibilities.
Everything goes right as long as i'm not building the corners. Once i do that curtain wall system's grid is becomming angled (not just vertical and hirizontal) and I can't rotate it.
Images attached.
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Click the curtain wall as a whole . . . . . are getting the instance properties to adjust the curtain wall grids ?
See attached inage.
2 Posts No Rating |
In those walls which are closing the corners Ican only adjust offset. Angle adjustment is not available.
curved curtain system -diagonal grid system? |
Wed, Feb 11, 2009 at 4:24:47 PM
Curtain Wall Grid Angle |
Tue, Feb 15, 2011 at 2:42:32 PM
curtain grid angle |
Wed, Feb 11, 2009 at 4:27:26 PM
Curtain Grid Problems [ 1 2 ] |
Wed, Apr 10, 2013 at 5:57:45 AM
19
Curtain wall grid |
Sat, May 28, 2016 at 9:58:45 AM
Members: | 2017148 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
