139 Users Online (136 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Uniformat assembly codes
Thu, Jan 31, 2013 at 10:03:32 AM | Uniformat assembly codes
havoc1
Hello All,
I'm adding assembly codes to components in an architecture model and i've come across a modified wall that i cannot add an assembly code to. When i click on Edit type a blank type properties box pops up....
please advise
Thanks,
Danny
Thu, Jan 31, 2013 at 10:07:52 AM | Uniformat assembly codes
Could this be a modeled in place wall?
Thu, Jan 31, 2013 at 10:09:58 AM | Uniformat assembly codes
havoc1
no, it's a modified stacked wall
Thu, Jan 31, 2013 at 10:24:58 AM | Uniformat assembly codes
A stacked wall is just that - stacked "walls".  Edit each seperate wall type used in the stack.
Thu, Jan 31, 2013 at 10:39:37 AM | Uniformat assembly codes
havoc1
cannot edit the stacked wall seperately. please see attached
Thu, Jan 31, 2013 at 10:56:34 AM | Uniformat assembly codes
You are in the wrong place.  The individual wall types are in your browser under walls.  Find them there and edit.
Again - A stacked wall is not really a wall type.  It is a stack of walls.  Ea wall within the stack is a wall definition.  The individual walls are ach taggable - the stack is not.
Thu, Jan 31, 2013 at 11:00:24 AM | Uniformat assembly codes
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I believe WWHub is saying you need to edit "Edit each seperate wall type used in the stack."
Meaning the actual wall type that is being used in the stacked wall, not edit the stacked wall itself but the walls that make up the stacked wall.
WWHub beat me to the response
Edited on: Thu, Jan 31, 2013 at 11:00:57 AM
Thu, Jan 31, 2013 at 11:21:12 AM | Uniformat assembly codes
havoc1
Awesome....it worked!
Thank you so much for your time and patience
Danny
Uniformat Assembly Codes: Revising
Tue, Oct 7, 2008 at 3:52:20 PM
help scheduling rooms with assembly codes
Thu, Jun 6, 2013 at 11:02:20 AM
Creating a Schedule showing all Assembly Codes
Tue, May 17, 2005 at 2:48:24 PM
Keynotes, assembly codes or material tags
Wed, Jun 23, 2021 at 12:11:00 PM
about the uniformat codes
Wed, Jan 28, 2009 at 6:17:10 AM
Page generation time: 0.2197
