33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface patterns
Thu, Jan 31, 2013 at 8:31:56 AM | Surface patterns
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
I have an area of brick that is towards the front of the drawing that i need to be darker, and as the walls in elevation step back they need to be lighter. since i cant set the thickness of the surface patterns how can i adjust the darkness ot lightness of the lines as they step bac in elevation.
Pete
revit 2011
Thu, Jan 31, 2013 at 8:37:36 AM | Surface patterns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can click on the wall in the view that you want to be lighter right click and override graphics in view by element and under the view-specific elements graphic dialog box change the surface pattern to a lighter color
Thu, Jan 31, 2013 at 8:56:12 AM | Surface patterns
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
thats what i have been doing, but the pattern does not "punch" thru it stiil gets lost. I kow it is not cad, but in cad i can set a pattern to a color and it prints that thickness. what i want to do is be able to print that suirface pattern at .007 and my farther back patterns AT .004. we can change projection lines of items. all i want to do is change the "projection" line of the suface pattern.
Thu, Jan 31, 2013 at 9:11:08 AM | Surface patterns
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
i changed my line wt 1 to 007 for my scale factor of the elevations i am working on. since i am not using that line wt anywhere else my pattern lines are at 007 now. and i can set the color slightly lighter for the retreating facades and it gives me the desired affect. it would be nice just to change the suface pattern line wt to 4 which is my 007. rather thatn having to sneak around the bush to get it done.
Thanks
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
materail surface patterns
Fri, Jun 13, 2008 at 8:06:11 AM
No Surface Patterns in Perspective
Thu, Feb 1, 2007 at 4:55:53 PM
Page generation time: 1.4960
