52 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Framebuffer (HDR / openEXR)
Wed, Jan 30, 2013 at 12:03:57 PM | Framebuffer (HDR / openEXR)
PeteS
Hello all,
short question: Is there any possibility to access the framebuffer for saving a HDR or openEXR?
As you can see here, the framebuffer obviously stores such data and therefore you can adjust the Exposure:
www.youtube.com/watch?v=Xtd2iWtn95E&feature=player_detailpage#t=190s
Any help is highly appreciated, thank you!
Regards, Pete
Edited on: Wed, Jan 30, 2013 at 12:06:07 PM
Thu, Feb 28, 2013 at 12:53:46 PM | Framebuffer (HDR / openEXR)
doberse
It seems that according to Autodesk this isn't possible. You could try the following as a possible workaround:
1. Render normally.
2. After rendering save multiple tiff files with different exposure values (Try adjusting the exposure and saving an image at every two values between 4 and 14).
3. You can then Merge To HDR in Photoshop and the result is a 32-bit file with high dynamic range. You just have to be sure to assign the proer EV values to each image in the set during Photoshop's merge process.
I just used this method on a storefront rendering for a client to balance out lighting levels and it worked fairly well.
Hope it's helpful to you,
Steve
Mon, Mar 11, 2013 at 5:44:08 AM | Framebuffer (HDR / openEXR)
PeteS
Hello Steve and thanks for your answer!
Yes, I am aware that such a possibility is existent but unfortunately I really need 'raw' High Dynamic Range data - without tonemapping. It is really a pitty that such an expensive tool like Revit does not offer HDR. Furthermore I have found a lot of bugs while testing Revit so I do not think that my customers and I will spend so much money to buy it.
Regards, Pete
Creating Hills! Help Please
Wed, Oct 15, 2008 at 7:35:35 PM
How do you create a 1"/2 = 1' scaled view ? I'm lost.
Thu, May 14, 2009 at 8:37:29 PM
Page generation time: 1.1859
