36 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Nested Door Panel not working
Wed, Jan 30, 2013 at 9:28:05 AM | Nested Door Panel not working
prestijio
Ok,
I've spent the better part of two days trying to figure this out, I am working on a nested door family for my office and came to a stoping point.  the problem I am having is that after I nest my door panel into the Host family I can't get it to flex with the frame, so if the door size changes in the project the frame will adjust and the panel will remain the same size as when it was inserted.  I have looked into origin points and I dont understand that to well so I am not sure if thats my problem.  Can someone please help?
Thanks in advance.
Arturo
Wed, Jan 30, 2013 at 9:30:56 AM | Nested Door Panel not working
I did not open family.
Do you have parameters for the nested family that are controlled by parameters in the host family?  Please read similar threads.
Wed, Jan 30, 2013 at 9:33:44 AM | Nested Door Panel not working
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In your nested door change your width parameter to be by Instance instead of type.
Wed, Jan 30, 2013 at 10:11:08 AM | Nested Door Panel not working
prestijio
Dimension change worked.
Thanks,
Nested 3d door panel parametric swing and the width problem
Tue, May 21, 2013 at 7:58:02 AM
11
Door with nested panels
Fri, Sep 2, 2011 at 8:09:21 AM
Nested Door Families and Door Schedules
Mon, Nov 8, 2010 at 2:56:47 PM
Thumbnail preview for NESTED Revit Families
Tue, May 14, 2013 at 5:18:21 AM
Nested families stored in project - Not in family
Mon, Jun 20, 2011 at 4:21:13 PM
Page generation time: 0.6914
