140 Users Online (139 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ceiling Level Keeps Showing up
Mon, May 24, 2004 at 3:35:37 PM | Ceiling Level Keeps Showing up
mick325
Hello, I'm having this problem where a level called "ceiling" appears on all my section and detail drawings. I don't have a level called "ceiling" anywhere in this project and the ceiling level shows up as a halftoned level marker. I can't tab-select it or click on it, manipulate it or figure out how to turn it off! I have a screenshot saved as a .bmp file if anyone cares to see this. I would greatly appreciate anyones help or assistance in helping me with this. Thanks! Mick mick325@hotmail.com
Mon, May 24, 2004 at 3:55:19 PM | RE: Ceiling Level Keeps Showing up
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
We've also had this problem and I've asked around and nobody seems to know how to fix it... I think it's a bug in release 6.
Hiroshi Jacobs
Mon, May 24, 2004 at 6:52:03 PM | RE: Ceiling Level Keeps Showing up
marchitect
Unfortunately, your only recourse for now is to 1) get in touch with Revit support staff 2) let them know you have a ghost level, 3) send them the file 4) they will fix it for you Just so you will know, Revit will document your case and then send you a link to a Buzzsaw site for you to upload your file to them. If you don't have Buzzsaw, they will send you a link to download the program. I sent a file a couple of weeks ago and they were pretty quick to respond and take care of the problem. Hope this helps, marc
Mon, May 24, 2004 at 8:18:23 PM | RE: Ceiling Level Keeps Showing up
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
We have also had the same problem. I believed it is fixed in the latest build of 6.1.
Regards,
Chris.
Sat, May 29, 2004 at 10:33:14 AM | RE: Ceiling Level Keeps Showing up
skisouth
5 Stars: 3 Votes
Per the old Zoogdesign forum (Now AUGI) - " ...successfullly copied and pasted into a new project to workaround the problem" Also noted on the forum - " This is a bug. The only way to get rid of these temp levels is to send the file into support and have them fix it.."
Ceiling Views not showing
Tue, Apr 27, 2010 at 1:08:36 PM
lighting fixture in multi-level ceiling
Tue, Jun 27, 2006 at 5:10:08 PM
LEVEL PROBLEM
Tue, Dec 16, 2008 at 10:17:18 AM
Ceiling Fixtures showing up on Floor Plans
Thu, Feb 7, 2013 at 7:31:59 AM
Reflected Ceiling Plan not showing revit link elements
Tue, Dec 7, 2021 at 6:55:57 AM
Page generation time: 2.0439
