Forums >> Revit Building >> Technical Support >> any work around for this? transparent glass in shaded elevation views, revit 201
10 Posts No Rating |
i need to show my glass curtain wall system as "real glass" in shaded with shadows elevation views. PLEASE dont tell me to use 3d
views instead and orient it to the neeeded elevation. because i need the level bubbles and grid bubbles shown which is not possible
in 3d views. thanks in advance.
Edited on: Mon, Jan 28, 2013 at 9:58:58 AM
Not sure what you are demanding.
You can have shaded elevation views.
None of your glass is real.
"i need to show my glass curtain wall system as "real glass" in shaded with shadows elevation views"
I'm not sure what you mean by "real glass" but if you are talkign about appearance this is all set in your Materials for your glass.
what i mean is transparent glass. see through glass in shaded (colored) elevations.
I just use the graphical 'override by element' and add surface transparency to either the one panel, all the panels or the entire category. So yes, it's do-able.
In print, We can see the elements behind the glass in shaded views but not in Hidden Line.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
Glass transparency in elevation view & split face command |
Sat, Mar 22, 2008 at 12:01:36 AM
Can the appearance of materials change by view type? |
Wed, Aug 5, 2015 at 4:04:03 PM
transparent glass in elevation |
Thu, Dec 22, 2016 at 3:43:04 AM
revit arch 2013 my 3d views are transparent???.. |
Mon, Mar 25, 2013 at 7:45:26 PM
Transparent material and shaded views. |
Tue, Mar 25, 2008 at 4:58:51 PM
Members: | 2097147 | Objects: | 23163 | Forum Posts: | 152288 | Job Listings: | 3 |
