73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall Hosted Family on Curved Wall
Mon, Jan 28, 2013 at 8:59:41 AM | Wall Hosted Family on Curved Wall
HP11
I am looking to create a wall hosted family for curved walls which ideally would take on the radius of the host.  I started with using the Generic Model Wall Hosted family template however the default wall is straight and references a straight reference plane.  Is it possible to modify the footprint of this wall or add a new curved host into this family and if so could you explain how to go about it?  One concern I have is that even if it is possible to get a curved host wall I will still be unable to curve my reference plane -  will this be problematic for creating and controlling the extrusion and it's placement in my model?  Are there other ways I should consider going about creating this family?  Thanks!
I am using Revit 2012.
Mon, Jan 28, 2013 at 9:03:08 AM | Wall Hosted Family on Curved Wall
The quick answer is no.  The wall template can not be modified as you ask.
You will not be able to do this in a manner that can read the host.  The curve will have to be inputted.  The family could still be face or wall based.  It will just not look right in the family editor.
Mon, Jan 28, 2013 at 3:12:43 PM | Wall Hosted Family on Curved Wall
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
This is possible, as an adaptive family with 3 adaptive points, a spline, and an extruded profile. The points of the family are placed on the curve of the wall, and if the wall changes length or radius, the points will adapt to the curved wall.
Planta1 Revit Online Consulting | info@planta1.com
Wall hosted family can't be hosted on curtain wall?!
Fri, Oct 22, 2010 at 7:13:05 AM
Wall hosted Families question
Thu, Jan 3, 2008 at 7:04:02 PM
Wall hosted family appears in schedule, but not in a room
Sat, Nov 19, 2011 at 12:58:15 PM
Cabinet Family which is Wall Hosted
Thu, Aug 4, 2011 at 11:09:07 AM
Wed, Feb 11, 2009 at 7:29:21 AM
Page generation time: 1.3151
