47 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> elevations missing
![4.5 Stars: 3 Votes](/images/stars_4.5.gif) |
I have jsut installed revit on a second machine and for some reason when you start a new project the elevations are not loaded in it. You have to go to the view toolbar and manually place them. Are there any settings to set each new project to load with the elevations already on. If so could you please explain
Thanks
Nathan
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Just create an empty project template (rte) and create in it the elevations you need. In the pulldown menu Options, Settings change on the tab File locations the Default Project template file to your new project template and ready you are.
Each time you press the New button this template is opened and you can start now
Levels Missing in Elevations |
Mon, Aug 26, 2013 at 12:20:14 PM
Printing elevations with shadows. |
Fri, Nov 1, 2013 at 3:39:51 AM
Default Elevations missing in project |
Fri, Apr 5, 2013 at 7:21:37 AM
Elevations missing |
Wed, Oct 16, 2013 at 7:24:39 AM
Missing windows in Elevation |
Fri, Apr 28, 2006 at 7:45:29 AM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
