28 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Shakey Interface
![1 Stars: 1 Votes](/images/stars_1.gif) |
I just loaded Revit LT 2013 (upgraded from Revit Architecture 2012) and I am experiencing a shakey interface everytime I select an object. When it stops jerking around the object moves several feet (or inches depending on scale factor. Is anyone else experiencing this?
Computer specs:
OS: Windows7 SP1
Processor: Intel Core i7-3630QM @2.4GHz
Memory: 8G
Video: Nvidia Quadra K1000M
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
I'd start by contacting your autodesk reseller with this one.
![alabaster2513 Avatar](user_avatar/28262.jpg)
![3.5 Stars: 25 Votes](/images/stars_3.5.gif) |
its the graphics driver, ive seen this many times.
![4 Stars: 7 Votes](/images/stars_4.gif) |
If it's the same issue I'm having, (this is true for 2012 and 2013) what's happening is the options bar is disappearing/appearing. I don't have a fix for it, and it appears to be a graphics card issue. For me it only happens when I open a second project (families don't seem to cause it) in a single Revit session. It doesn't matter if I close the first project or not, if I open another project without restarting Revit it will happen. Selecting/deselecting an element once or twice without doing anything else seems to stop it, as does restarting Revit.
Also, turn off Press & Drag (lower right hand corner). This will at least keep you from accidentally dragging elements if it does happen unexpectedly.
Anti-aliased Revit/WIndows interface? |
Tue, May 22, 2007 at 1:27:45 PM
12
Stop the yearly interface updates |
Fri, May 13, 2011 at 8:38:20 AM
How can I change the font of the entire interface? |
Wed, Apr 13, 2011 at 3:02:56 PM
Revit Architecture 09 - User Interface |
Thu, May 29, 2008 at 3:27:12 PM
Revit Interface Class Outline |
Wed, Nov 2, 2011 at 9:45:35 AM
Members: | 2025963 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
