Forums >> Revit Building >> Technical Support >> Schedule in design option
Mon, Jan 23, 2006 at 10:56:28 PM | Schedule in design option
jyothi
Hi, I have 3 different options to be worked out for a client inn terms of elevation. There is change in roof,which i am able to work.But the problem is there is variation in the type of window,door and only in wall material in front elevation only.To insert window i have created different walls in alll the option at same place is there any other way than this. And second question is how do we take care of schedule,those wall will be accounted twice even if i create different schedule and asign the option. i saw similar kind of thread posted ,but i was unable to browse through the link which was given by jobcaptian . Please help regarding this. Thanks,
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Walls in design option
Mon, Jan 23, 2006 at 10:58:33 PM
Design Options - black hole.
Wed, Feb 14, 2007 at 12:54:40 PM
Shcedulling design option doors & windows from a linked model
Mon, Mar 19, 2018 at 2:57:51 PM
Page generation time: 0.5306
