84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> How do you tell what finish has been applied with Paint?
Fri, Jan 25, 2013 at 6:38:02 AM | How do you tell what finish has been applied with Paint?
dustandchimes
Hi,
I used the paint tool to paint some walls and ceilings. Is there a way to see what colour/finish I applied to these? While doing some rendering I realised I missed a few bits and can't remember what finish I used. I should've wrote this down but it's my first project and I didn't think of that!
Thanks!!!!
Fri, Jan 25, 2013 at 8:35:04 AM | How do you tell what finish has been applied with Paint?
If your materials are built correctly with something in the Description line, you can use a material tag to see waht the surface of the wall is.  Works for the actual wall material or if painted, then the paint material.
Fri, Jan 25, 2013 at 8:53:01 AM | How do you tell what finish has been applied with Paint?
dustandchimes
Thanks, I'll give that a go tonight
Sat, Jan 26, 2013 at 5:09:27 AM | How do you tell what finish has been applied with Paint?
4 Stars: 202 Votes
Hover over your mouse to your painted wall and you'll see "... painted with...."
Sat, Jan 26, 2013 at 5:14:42 AM | How do you tell what finish has been applied with Paint?
dustandchimes
I realised this last night. I was just trying to figure it out without the paint tool open. Thanks for the help!
Applying Wall Finish and Scheduling It?
Fri, Jun 14, 2013 at 7:24:10 AM
Walls - Paint Layer
Tue, Feb 12, 2013 at 7:59:07 AM
different Material/Paint/Texture/Finish to inside and outside faces of the wall
Tue, Aug 25, 2009 at 3:57:51 PM
Paint material to stairs soffits
Tue, Oct 31, 2017 at 6:51:00 PM
Help with finish tags
Wed, Nov 17, 2010 at 3:14:35 PM
Page generation time: 0.7744
