29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> custom curtain panel
Thu, Jan 24, 2013 at 2:15:33 PM | custom curtain panel
ScubaMan
Hello, I was wondering if someone could look at the curtain panel in the link at the end and tell me what the best way to model it would be. I am familiar with how to make custom curtain panels where every panel is the same however in this example the panels angle in on one then angle out on the next floor. Would the best way be to model a section of four panels but make revit think it was one? Or is there a way to ungulate the panels without having to manually change each one?Thank you for you time
http://larseric.wordpress.com/2010/04/01/350-mission-st-san-francisco-ca-som-architects/
Thu, Jan 24, 2013 at 3:37:58 PM | custom curtain panel
These would be best just as families - not CW panel.  Use an empty CW panel if you still want "mullions"
Thu, Jan 24, 2013 at 4:51:22 PM | custom curtain panel
ScubaMan
Thanks for the quick reply and insight. I was stuck on doing it as a CW but doing it as a family does make a lot more sence.ThanksSmile
Thu, Jan 24, 2013 at 5:50:12 PM | WWHub
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Quoting WWHub from 2013-01-24 15:37:57
"These would be best just as families - not CW panel. ...
??? Is it not a CW panel a family, too?
Planta1 Revit Online Consulting | info@planta1.com
Fri, Jan 25, 2013 at 7:22:14 AM | custom curtain panel
alf - you know it is... busting my chops?
I should have probably said something like - Don't do this as a CW Panel family.  Use a different family category that is easier to control.  Maybe a generic model?
Fri, Jan 25, 2013 at 8:29:17 AM | custom curtain panel
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
I think the curtain wal panel family is the best option in this case.
Fri, Jan 25, 2013 at 8:29:38 AM | custom curtain panel
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
I think the curtain wall panel family is the best option in this case.
(Sorry for the duplicated post). The server seems to be slow today, and I hit "submit" twice, thinking that it was not working.
By the way, another question. Is there a way to change one's username? I like to use my name in all the forums, but here I had created an account a long time ago as "alfmedina". I would like to change that to "Alfredo Medina". Can an administrator do thatfor me, please?
Edited on: Fri, Jan 25, 2013 at 8:33:23 AM
Fri, Jan 25, 2013 at 8:41:12 AM | custom curtain panel
alf - no way to change your name, you would have to create a new account and start over on your history.  You can edit your profile for anything else.
I disagree with you about using a curtain panel but maybe you are only talking about the outer glass element.  That would be OK.  But if you look, there is a double system here.  The mullioned glass, the X panels back to a second mullioned panel with cross "mullions" between tem.
The 'X's would be better as a family, alternate rotation.
Edited on: Fri, Jan 25, 2013 at 8:42:04 AM
Fri, Jan 25, 2013 at 10:55:37 AM | custom curtain panel
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
The curtain wall panel family is very versatile.
Fri, Jan 25, 2013 at 11:18:01 AM | custom curtain panel
I will bow to your better experience with these.
Perhaps you could post that panel family so we can all see how you did it.
Thanks
BTW - Do you have teo CW's in the same place - one for glass and the other for the X?
Fri, Jan 25, 2013 at 11:52:35 AM | custom curtain panel
#11
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
This is all what is inside the custom panel family:
Edited on: Fri, Jan 25, 2013 at 11:52:58 AM
Slope Roof with custom curtain panel
Fri, Dec 4, 2009 at 12:35:09 AM
custom shape of curtain panel results in panel replacing
Mon, Apr 12, 2010 at 12:17:29 PM
Wood Screen - Curtain Panel
Sat, Jan 10, 2015 at 1:44:01 AM
Loading Custom Curtain Wall Panel into file
Mon, Sep 15, 2014 at 9:19:42 AM
Custom panel family within a curtain system
Tue, Nov 3, 2009 at 11:59:11 AM
Page generation time: 0.4729
